Message 1 of 14
Zero Upload Speed
Over the last 2 to 3 weeks my upload speed has reduced down to nothing. It's now almost impossible to upload any files to any locations, making home working impossible. I've tried wired and wireless connections an no difference. I've also taken the faceplate off the main connection point and connected directly with no difference.
Collating the information I can, I can share the following information:-
Fibre Broadband (VDSL)
Downstream sync speed 24.782 Mbps
Upstream sync speed 4.252 Mbps
Product code:Smart Hub 2
Serial number: +091298+1945005679
Firmware version:v0.21.03.07094-BT
Firmware updated:Mon Sep 7 09:14:59 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:5 days,01 Hours13 Mins48 Secs
Data rate:4.252 Mbps / 24.782 Mbps
Maximum data rate:4.381 Mbps / 31.510 Mbps
Noise margin:6.5 / 5.9
Line attenuation:13.2 / 23.8
Signal attenuation:11.3 / 20.6
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:16.1 GB Uploaded / 84.8 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:LanSolo
2.4 GHz wireless channel:Smart (Channel11)
5 GHz wireless network name:LanSolo
5 GHz wireless channel:Smart (Channel44)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:0C:8E:29:33:F7:7E
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Summary of Performance Test
Timestamp Monday 16 November 2020 | 18:57:4
Ping 38 Ms
Download 18.07 Mbps
Upload 0 Mbps
Advance Test
Download Test
Download speed achieved during the test was 18.07 Mbps
For your connection, the acceptable range of speeds is 20 - 23.99 Mbps
IP Profile for your line is 23.99 Mbps
Upload Test
Upload speed achieved during the test was 0 Mbps
IP Profile for your line is 10 Mbps
Tracert Result
1 2 ms 13 ms 3 ms BTHUB6DX [192.168.1.254]
2 * * * Request timed out.
3 * 69 ms 66 ms 31.55.187.177
4 * 344 ms 209 ms 31.55.187.176
5 28 ms 32 ms 26 ms core1-hu0-6-0-8.southbank.ukcore.bt.net [213.121.192.76]
6 72 ms 97 ms 369 ms peer7-et-0-0-2.telehouse.ukcore.bt.net [62.172.103.160]
7 43 ms * 154 ms 166-49-214-194.gia.bt.net [166.49.214.194]
8 33 ms 39 ms 38 ms 166-49-214-191.gia.bt.net [166.49.214.191]
9 135 ms 105 ms 106 ms ae2.cr2-nyc2.ip4.gtt.net [89.149.129.198]
10 455 ms 180 ms 306 ms ip4.gtt.net [173.205.45.210]
11 * 390 ms 370 ms 64.21.118.97
12 108 ms 352 ms 112 ms 64.21.118.114
13 124 ms * * dar5.mmu.nac.net [209.123.11.5]
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Exchange BLYTHE BRIDGE is served by Cabinet 11
Thanks,
Steve
13 REPLIES 13
Message 2 of 14
Re: Zero Upload Speed
check for line noise. Dial 17070 option 2 should be silent and best with corded phone preferably from test socket
try running speedtest.net and see if you still get no upload speed
stats suggest uploaded 16gb in the 5 days connected
Message 3 of 14
Thanks,  there's no line noise, it's perfectly quiet.
Speedtest.net shows 0Mbps upload as well.
I'm surprised by the 16gb figure. We've recently installed a ring doorbell and I was convinced this was the culprit but it's set to only respond to someone pushing the button, not a constant upload
Message 4 of 14
Have you done a factory reset by pressing the recessed button on back and hold for 20/30secs until lights flash. When hub reboots remember turn of smart setup
Message 5 of 14
Factory reset done and smart setup cancelled. Speed test now shows lower download sites and still no upload speed
Message 6 of 14
Can't see what more you can do just need to phone 150 and get engineer visit
Message 7 of 14
Thanks for your help and suggestions
Message 8 of 14
Update on this. I'm dealing directly with the Executive Customer Resolution Team. I've now had three Openreach engineers look at the problem and each say there is no issue with the line or the line speed. The first one replaced the mastersocket for one with a combined filter, reset my smart hub and told me everything should be fine. It had slowed by the time he'd exited the street. The second engineer couldn't find anything at all, reset the smart hub and ordered me a replacement but didn't tell me. The third engineer checked the master socket and said there was a loose connection so that would be the issue. This "fix" lasted the longest, for about 48 hours before the poor upload speed returned.
I've been keeping a log of my ping, download and upload speeds each day and have noted the upload drops off significantly around lunchtime each day.
13/12/2020
10:41am - Ping 43, d/l 22.45, u/l 1.22 wireless and Ping 54, d/l 21.86, u/l 0.54 Wired
1:44pm - Ping 43, d/l 21.04, u/0.39 wireless and Ping 42, d/l 30.23, u/l 0.66 Wired
6:32pm - Ping 42, d/l 21.17, u/l 0.00 wireless
18/12/2020 Engineer found loose connections in master socket
2:20pm - Ping 27, d/l 34.25, u/l 3.57 wireless
8:30pm - Ping 28, d/l 34.75, u/l 3.25 wireless
21/12/2020
1:30pm - Ping 28, d/l 32.89, u/l 0.68 wireless
26/12/2020
10:45am - Ping 27, d/l 32.27, u/l 1.12 wireless and Ping 28, d/l 34.29, u/l 1.20 wired
3:57pm - Ping 27, d/l 33.65, u/l 0.67 wireless
8:24pm - Ping 28, d/l 31.79, u/l 0.56 wireless
29/12/2020
10:54am - Ping 27, d/l 29.57, u/l 0.48 wireless
5:30pm - Ping 15, d/l 32.60, u/l 0.52 wireless
30/12/2020
10:34am - Ping 27, d/l 35.51, u/l 1.77 wireless
11:56am - Ping 26, d/l 36.98, u/l 2.75 wireless
3:35pm - Ping 27, d/l 31.96, u/l 0.81 wireless
7:22pm - Ping 27, d/l 30.68, u/l 0.64 wireless
31/12/2020
10:02am - Ping 27, d/l 34.08, u/l 1.21 wireless
Shortly after this test I reinstalled my mesh network to see if this made any difference to afternoon speeds.
1:23pm - Ping 30, d/l 31.78, u/l 2.04 wireless
4.25pm - Ping 29, d/l 31.26, u/l 0.48 wireless
8.25pm - Ping 31, d/l 29.87, u/l 0.07 wireless
01/01/2021
I removed my mesh network
9:20am - Ping 27, d/l 25.24, u/l 0.01 wireless
10:33am - Ping 27, d/l 23.41, u/l 0.03 wireless
11:24am - Ping 27, d/l 28.22, u/l 1.00 wireless
2:32pm - Ping 27, d/l 28.46, u/l 0.98 wireless
7:47pm - Ping 27, d/l 21.36, u/l 1.17 wireless
02/01/2021
11:17am - Ping 27, d/l 29.22, u/l 1.97 wireless
3:07pm - Ping 26, d/l 29.10, u/l 0.34 wireless
8:18pm - router lost connection (not reset)
9:16pm - Ping 27, d/l 27.52, u/l 0.78 wireless
Message 9 of 14
Openreach engineer visited again this morning and said the line was operating exactly as it should and there was no record of any line issues - he showed me a graph going back to 10th November. After dicussion with him I said I'd try an old TP-Link TD-W9980 router I had sitting on the garage shelf. Speedtest.net results from today are:-
04/01/2021
09:00am - Ping 17, d/l 36.84, u/l 0.36 wired
09:02am - Ping 26, d/l 37.38, u/l 2.04 wired
09:04am - Ping 27, d/l 30.12, u/l 2.44 wireless
09:54am - Ping 27, d/l 27.34, u/l 1.7 wireless
Router swapped
11:38am - Ping 40, d/l 27.74, u/l 3.52 wireless
2:20pm - Ping 33, d/l 26.99, u/l 1.27 wireless
5:01pm - Ping 39, d/l 26.11, u/l 3.79 wireless
It's looking a little more promising and I'm now able to send an email with an attachment. I'll keep monitoring the performance to see what happens over a longer period of time.
Message 10 of 14
Ok, no further forward with this, the upload speed drops and I end up with emails sitting in my outbox unable to send - not good for working from home. I also can't upload any files to the work server - not even an 8mb file, it drops the connection roughly halfway through and even then it's only uploading at 335kbps. Speed test results yesterday and this morning are:-
05/01/2021 - all on work laptop
2.34pm - Ping 31, d/l 37.17, u/l 0.52 wired connection
4.46pm - Ping 29, d/l 20.89, u/l 0.52 wired connection
5.06pm - Ping 31, d/l 37.27, u/l 0.76 wired connection
5.28pm - Ping 28, d/l 30.93, u/l 0.14 wired connection
06/01/2020
8.22am - Ping 30, d/l 37.24, u/l 4.26 wired connection
10.51am - Ping 30, d/l 35.91, u/l 0.58 wired connection
2.46pm - Ping 28, d/l 30.84, u/l 0.13 wired connection
I've noticed there is a lot of packet loss on the upload side compared to the download side. Could this be a factor?
System Up Time - 2 day(s) 03:46:11
Upstream Current Rate (Kbps) 7232
Upstream Max Rate (Kbps) 7267
Upstream SNR Margin (dB) 6
Upstream Line Attenuation (dB) 38.9
Upstream Errors (Pkts) 259
Downstream Current Rate (Kbps) 39995
Downstream Max Rate (Kbps) 47712
Downstream SNR Margin (dB) 6.3
Downstream Line Attenuation (dB) 24.2
Downstream Errors (Pkts) 16
Any ideas or suggestions please?
