Message 11 of 16
Re: can't send emails since this afternoon
Hey ho! Spark works fine on the MacBookPro. Things are looking dodgy for the iMac ...
Message 12 of 16
You could always try Mozilla Thunderbird, I believe they do a Mac version.
Message 13 of 16
I got Spark to connect to my btinternet account OK by resetting the server ports to 993 and 465. I cannot send any messages at all from Spark on the iMac. It would seem that my being able to send a message to my iCloud account from the iMac is an Apple peculiarity. Spark works a treat on the MacBookPro - no problems with sending messages at all. I wonder if its an OS problem (11.5 works; 10.15 doesn't)?
Message 14 of 16
Sorry, but as far as I'm concerned Apple products are the work of the devil and wouldn't give them house room. 😀
Message 15 of 16
Oops (again)! Spark made all the right noises when I sent the message but later it declared there was a problem and I needed to edit the message. I was, however, able to send the same message in Apple Mail without any issues. The message from Spark never appeared on webmail; the message from Apple Mail did.
Message 16 of 16
Thanks, liquorice, for your advice. The problem has mysteriously disappeared . It was there this morning at 0800 but it was gone by 1330. I seem to recall someone suggesting that it might and so it did. Hurrah.
