Message 1 of 5
crackling phone
Hi,
I was wonder if anyone has any advice.
My land line has been incredibly 'crackly' for past few weeks. I just haven't had time to sort it out. If the phone rings or a go to try and use it (which is pretty impossible), then the internet cuts out for a couple of minutes.
I have tried plugging just the phone into the main socket, and it is no where near as crackly. Which would suggest there is a problem within my house?
Last night I tried the bt bot and it said they couldn't find a problem, however after it was supposed to have finished the internet was on and off for hours. In fact whilst trying to send this question, the internet has gone off twice. I don't want to call bt out, if it is my problem. I have had a crackling phone in the past, it usually corrects itself with a few day/ a week.
Thank you in advance
4 REPLIES 4
Message 2 of 5
Re: crackling phone
which master socket do you have?
if you use a filter have you tried a new filter?
Message 3 of 5
Re: crackling phone
Thank you for your reply.
I have number 2. I've just tried a new filter and it does not seem to have made any difference
Message 4 of 5
Re: crackling phone
have you tried connecting to test socket by removing the bottom half of master and then dial 17070 option 2  should be silent and best with corded phone.  if you still get noise/crackle then report phone fault to 151 or 0800800151 from mobile
Message 5 of 5
Re: crackling phone
I have done the silent line test and there is still noise. I have rang bt and they did check and recommend an engineer visit.
Thank you for your help
