Message 11 of 21
Re: fttp install
thnk you so up to engineer then
Message 12 of 21
Re: fttp install
No, it is dependent on the method employed in your area.
Message 13 of 21
Re: fttp install
ok thank you
Message 14 of 21
Re: fttp install
does the ont need to be close to where the fibre comes in
Message 15 of 21
Re: fttp install
EZ Bend Cables come in pre made lengths of 5, 10, 20, 30 and 50m.
Message 16 of 21
Re: fttp install
is that the cable from csp or from phone pole
Message 17 of 21
Re: fttp install
Depends if a CSP is used or not.
Message 18 of 21
Re: fttp install
thank you, basically i need to find other installations in the area TO see if a CSP is used. i cant request a non CSP installation?
Message 19 of 21
Re: fttp install
No you cannot.
Message 20 of 21
Re: fttp install
thank you
