Message 1 of 21
fttp install
hi, I'm thinking about upgrading from superfast to fttp. but what changes are needed? any external boxes/junctions and internal boxes.
20 REPLIES 20
Message 2 of 21
Re: fttp install
@Garthy
How is your service currently provided?
Via an ONT I assume?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 3 of 21
Re: fttp install
no i still have fttc and copper wire
Message 4 of 21
Re: fttp install
If FTTP is available then an engineer would be required to supply the fibre and fit the ONT. What does the CHECKER say when you input your phone number?
Message 5 of 21
Re: fttp install
fttp is available wbc
Message 6 of 21
Re: fttp install
is there an external splitter box
Message 7 of 21
Re: fttp install
What is an external splitter box for FTTP? You seem to know more than we do.
Message 8 of 21
Re: fttp install
i was told before the fibre cable had to be put through a box on the outside wall as it wasnt flexible and was told it was a splitter box
Message 9 of 21
Re: fttp install
It's called a CSP and some installs have it and some don't - my fibre cable just goes straight through the outside wall to my ONT for example.  I think there were problems with the connector and OR are reverting to using an outside CSP - it's just a splice point where the external fibre optic cable is spliced to the internal cable.
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
Message 10 of 21
Re: fttp install
thank you. i didnt want another box on my wall as its right by my front door
