Message 1 of 20
fttp
On fttp, what are the pros and cons of turning off broadband at the smart hub
19 REPLIES 19
Message 2 of 20
Re: fttp
There are no pros but a con is that you won't have a connection if you turn it off.
Message 3 of 20
Re: fttp
@DaveBennett
Do you mean with regards to it affecting the service?
I don't believe it's ever recommended to turn off a device like a Router, however as it's the PON device that handles the connection, I am not sure what effect it may have, if any.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 4 of 20
Re: fttp
Message 5 of 20
Re: fttp
That is not a con if I am wanting to turn off broadband at night to prevent access by a child overnight!
If it is turned off at the hub with the modem still working will it show up as an unstable line?
Message 6 of 20
Re: fttp
No. It is FTTP anyway so DLM isn't involved.
Message 7 of 20
Re: fttp
The smart hub has a facility to disconnect the broadband but I have been unable to find any reference to its use.
What I would like to find out is if I use that facility will it reflect in the fttp circuit being seen as unstable such that the line speed is reduced.
Message 8 of 20
Re: fttp
Sorry, what is DLM?
Message 9 of 20
Re: fttp
The system that monitors stability on FTTC
Message 10 of 20
Re: fttp
Many thanks. I think that has answered my query.
