Message 1 of 3
how do i cancel an extra tv box that is no longer used
2 REPLIES 2
Message 2 of 3
Re: how do i cancel an extra tv box that is no longer used
You can call 0800 800 150, speak with the Loyalty or Value team and give 30 days notice to remove it, if you were sent a Youview box for the 2nd box subscription, you'll receive a returns bag to send it back, unless you've had it since before 19/12/2019 in which case you can keep it.
Message 3 of 3
Ok thanks, will call them now.
