Message 1 of 9
network connections
In network connections I have 2 network adapters. Network 2 has a red cross in it, network 3 is connected. I want to use network 2 and thought if I disabled network 3 this would work, but it hasn't.
If I uninstall network 3, will I then be able to use network 2 or will I be left with no internet?
8 REPLIES 8
Message 2 of 9
Re: network connections
What type of adapter are network 2 and  3, Ethernet or WiFi , are they both connected. Why do you wish to use one adapter rather than the other?
Message 3 of 9
they are ethernet. Network 2 has my antivirus name on it, not sure what 3 is
Message 4 of 9
Do they both have Ethernet cables plugged in?
Message 5 of 9
No there is only one ethernet port on my cpu. Network 3 is using it
Message 6 of 9
So why do you want use network 2, which doesn't have a connection?
Message 7 of 9
because it has my antivirus name on it, network 3 has realtek on it, which I know nothing about.
Message 8 of 9
That is the manufacturer of the NIC.  Just use that.
Message 9 of 9
Thank you for your help. Things are a little clearer now.
