Message 1 of 2
ping spikes
Basically got full fibre 900mb but im dying in absolutely absurd ways on call of duty so did a ping plotter, is this a normal result or is it far spikier than it should be?
1 REPLY 1
Message 2 of 2
Re: ping spikes
That’s looking ok, the spikes are hitting around the 20 to 25ms so should not be an issue as such.
COD servers tend to try equal out the playing field with what some call lag compensation plus when you fire up into a server it decides which one you join unless you have a router with geo fencing/filter.
