Message 1 of 3
Blocked Ports
Hello, Has anybody had issues with blocked ports since moving to full-fibre, I have a server at home and since moving to full-fibre I am unable to use its VPN all port forwarding is in place and worked on FTTC connection but the UDP ports 1703,4500 and 500 look to be blocked on fibre as confirmed on yougetsignal.com. I did call support last week and he said I will look into it but never came back and the person on chat just now had no idea what I was talking about 😞
So any advice/help would be most welcome
2 REPLIES 2
Message 2 of 3
Re: Blocked Ports
BT don't block specific ports. The ports won't be open unless the application is listening on those ports.
Message 3 of 3
Re: Blocked Ports
Thanks for the reply and confirming they don't block ports after some more work turns out router firmware is the issue all resolved now  Cheers
