Message 1 of 3
power cuts question
I was reading some posts that the Smart hub goes wrong or breaks after a power cut, I have a wifi disc to.
They were old posts. Is it better now and copes ok?
We get a one now and then where we are, sometimes those quick off and on ones.
I have on each socket the plug in surge protectors now.
Also not sure will get if ok with surge protectors; but interested how those UPS work anyone have a link of ones they use that are cheapish lol, also with 3 plugs (fibre box, router and wifi disc in another room), would need 3?.
2 REPLIES 2
Message 2 of 3
Re: power cuts question
You won't have a power cut breaking the hub so don't worry about it, surge protectors will be OK too. Links to commercial sites are not allowed. There are many online reviews of UPS systems it all depends on what you require.
Message 3 of 3
Thanks, if surge protectors ok, thats ok then.
thanks
Shirl
