Message 1 of 4
slow broadband
on the last 2 days my fibre halo 1 broadband download speed has dropped from around 70Mbps to around 10Mbps today its at 9.2Mbps any suggestions looking for help to fix this problem any ideas ? i have home hub 5
3 REPLIES 3
Message 2 of 4
Re: slow broadband
@lesterlad
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Message 3 of 4
Re: slow broadband
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 4 of 4
Re: slow broadband
After close inspection of my hub I discover it has a reset option, which I activated and everything is now back to normal (70Mbps). Thanks to everyone for their help
