Message 61 of 62
Re: uploading kills my download speed
The problem was buffer bloat. Seems to be more of a problem where upload speeds are capped at 1Meg (ADSL).
Problem solved by replacing bt hub with a router that has  Q o S  and can prioritise device upload/download speeds.
Message 62 of 62
So the way this was fixed was to NOT use the BT hub? This is hardly a decent solution BT is it.
