Message 11 of 62
Re: uploading kills my download speed
All set up and so far so good, thanks very much for your help.
The last engineer upped my snr to 9db, how do I get this put back in order to get a bit more overall speed?
Message 12 of 62
The SNR has to be lower, to get a speed increase. Its automatically controlled.
Can you please post the connection information from the TP Link, it should be easy just to cut and paste like I did, from the status page.
I assume its the W9970 you are using?
Message 13 of 62
The last engineer said he had "set" the SNR at 9Db in a effort to sort the problem rather than let it set automatically.
Yes I have the W9970, seems great for the money.
         DSL
Line Status:
DSL Up Time:
DSL Modulation Type:
Annex Type:
  Upstream Downstream
Current Rate (kbps)93015477
Max Rate (kbps)93017572
SNR Margin (dB)11.69.1
Line Attenuation (dB)17.139.9
Errors (pkts)10
Message 14 of 62
         DSL
Line Status:
DSL Up Time:
Annex Type:
  Upstream Downstream
Current Rate (kbps) 930 15477
Max Rate (kbps) 930 17572
SNR Margin (dB) 11.6 9.1
Line Attenuation (dB) 17.1 39.9
Errors (pkts) 1 0
It may have been done to improve stability. Did you have problems with disconnections?
Message 15 of 62
No, maybe once in a blue moon
Message 16 of 62
I can ask a moderator if they can release the fixed setting, as that is something they can do if you really want it.  It can drop to as low as 3dB, mine varies between 2.9 and 3dB.
You may gain a bit of speed. If it becomes unstable, then the SNR will automatically adjust upwards.
Message 17 of 62
Yes, that would be great. And many thanks once again for all your help.
Message 18 of 62
Will they need my landine no?
Message 19 of 62
If they can help, they will request the information by private message.
Watch this space.
Message 20 of 62
