Message 1 of 8
voice fauly fixed... but broadband even slower
Ok they seem to have fixed the voice fault a couple of days ago. but the fibre is getting slower and slower...
Diagnostic below.
Basic Performance Test -
Time Stamp Latency Download Upload
Wednesday 27 May 2020 | 16:49:1 32 Ms 13.63 Mbps 8.44 Mbps
Advanced Performance Test -
Download Test
Download speed achieved during the test was 13.63 Mbps
For your connection, the acceptable range of speeds is 40-73.75 Mbps
Your DSL Connection Rate: 0 Mbps(DOWN-STREAM),0 Mbps(UP-STREAM)
For your connection, the maximum achievable download speed is 73.75 Mbps
IP Profile for your line is 73.75 Mbps
Upload Test
Upload speed achieved during the test was 8.44 Mbps
For your connection, the maximum achievable upload speed is 20 Mbps
IP Profile for your line is 20 Mbps
Summary Advanced Performance Test -
Result Message
This test was not conclusive and further testing is required.This might be useful for your Broadb
7 REPLIES 7
Message 2 of 8
Re: voice fauly fixed... but broadband even slower
From what you have posted the profiles are what I would expect if your connection speed is at max 80/20mb
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Message 3 of 8
Product code:Smart Hub 2
Serial number:+
Firmware version:v0.17.01.12301-BT
Firmware updated:Tue Mar 17 06:08:44 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:0 days,03 Hours15 Mins10 Secs
Data rate:19.999 Mbps / 79.998 Mbps
Maximum data rate:24.557 Mbps / 81.887 Mbps
Noise margin:15.3 / 3.2
Line attenuation:8.9 / 12.4
Signal attenuation:8.9 / 14.0
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:2.1 GB Uploaded / 1.4 GB Downloaded
Message 4 of 8
So connection speed is ok and line appears ok as 3dn noise margin suggests G.INP active
can your run btspeedtester and post results must be done with the rent connection not wireless
https://speedtest.btwholesale.com/
Message 5 of 8
Your Sync Rate won’t automatically go straight back to what it was prior to whatever line fault you had.
Either you’ll need to wait for the DLM to do it things or have your CP report an FTTC Fault and the Engineer can then do a DLM Reset.
Message 6 of 8
Oh, just saw your line stats. Looks like your DLM May have been reset already.
Message 7 of 8
Ok will give it a couple of days. see where we are.. only when i printed those stats did i see the uptime.  By the way...
Whats the Rent Connection?
Message 8 of 8
It should read wired connection.
