Message 1 of 20
My BT Homehub keeps rebooting
This happens multiple times a day, it's making it very hard to wfh. What fault-finding should I try?
Product: Bt Hub 6A
Firmware: SG4B1000E020
19 REPLIES 19
Anonymous
Not applicable
Message 2 of 20
Re: My BT Homehub keeps rebooting
A bit basic I know but have you checked the power adapter is plugged in properly at both ends and the integrity of the cable
Message 3 of 20
Yes, sorry, my bad description, it flashes red and drops the connection, then everything starts working again after about 30 seconds.
This happens multiple times per day.
Message 4 of 20
I'm seeing lots of these every day in the log:
15:00:01, 27 May.
:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
Anonymous
Not applicable
Message 5 of 20
Message 6 of 20
Just did it, I hope that sorts it out
Message 7 of 20
Thanks for the suggestion
Message 8 of 20
Do you have a new master socket 5c MK4 where the front clips on and no screws. If so there are posts where it did not clip on correctly and was slightly loose which caused drops in connection
Message 9 of 20
Looking good after the factory reset, I'll grep the logs for disconnections in a bit, but today will be my acid-test - lots of meetings.
I do have a 5cMk4, it didn't seem loose, but I popped it off and on again just to be sure.
Thanks everyone.
After doing a broadband test the system wanted to book an engineer for me - is this normal practice or does it indicate something may be amiss?
Anonymous
Not applicable
Message 10 of 20
I've had that message. I would just ignore it if everything's  working OK
