Message 1 of 3
2 Routers. Which one to use ?
Hi,
Not a computer whiz kid I'm afraid.😁
I have 2 Routers.
Which is best to use just for normal household broadband.
At the moment I'm using the one with blue light in the photo which BT sent me.  It's an EE BT one.
Or should I switch to a BT smart hub 2 which I have received also. the other picture ?
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: 2 Routers. Which one to use ?
I think they're the same device in different cases, so should make no difference which one you use.
Message 3 of 3
Thanks.
