Message 1 of 3
4600 compatibility with 4500 base station
My mother has 2 x BT 4500 handsets with answer machine base station. One of the handsets has been a bit crackly for a while, now the other one seems to have failed. The BT4500 seems pretty obsolete but 4600 is available, so my question is, can a 4600 handset work with a 4500 base station?
2 REPLIES 2
Message 2 of 3
Re: 4600 compatibility with 4500 base station
Hi @nicknorman979, thanks for your post. You should be able to use a different model handset with the base as long as both are GAP compatible
Can I use a different type of BT cordless phone with my existing base? | BT Help
Both these are showing as GAP compatible.
BT Studio 4500 | BT Help
And the quick set up guide for the BT4600 | BT Help does say 'You can register up to 6 GAP compliant handsets to your BT4600 base'
The contact number for the product helpdesk contact numbers are listed on the product help pages if you need further help.
Cheers
John
Message 3 of 3
Thank you for your swift reply.
