Message 1 of 2
BT 11ac Home Hotspot Plus 1000
My Home Hotspot was working happily for many many months, but then I had to disconnect the router. Ever since the BT powerline adaptors haven’t worked.
I have my router (Virgin Media) plugged into a BT Flex 1000 and the Home Hotspot plugged into a different 13amp socket.
I can see the Hotspot in my wireless options on my iPhone and I have inputted the password, but then nothing happens, it doesn’t connect. It looks as though it is trying to connect, but nothing.
Any suggestions why?
1 REPLY 1
Message 2 of 2
Re: BT 11ac Home Hotspot Plus 1000
Hi @bertilincoln I'm sorry to see you're having problems with your Home Hotspot plus 1000. Have you tried a factory reset to see if that helps?
Reset to factory settings
If your extender or hotspot stops working or becomes unpaired, you can reset both to
their factory settings:
1 Make sure the extender or the hotspot is plugged in and the power socket’s
switched on.
2 Press the Link button on the extender for more than 15 seconds or the Reset
pinhole on the hotspot for 1 second to restore factory default settings. Give it a
couple of minutes. If everything’s okay, the Power indicator on both will light up.
Neil
