Message 1 of 4
BT Baby Monitor 6000 sound light indicator
My BT baby monitor 6000 will flash the sound lights on the side of the device to indicate that there is noise, however there is no noise in the room.
There is no interference and it will happen sporadically flashing all the way to the red light at the top indicating a loud noise.
Monitor is 6 months old.
3 REPLIES 3
Message 2 of 4
Re: BT Baby Monitor 6000 sound light indicator
Hi @jessicaellis89, welcome to the forum and thanks for posting.
It would be best to speak with the BT Video Baby Monitor 6000 | BT Help as they are best placed to help you with this.
Cheers
John
Message 3 of 4
Called the number. BT have said they do not stock the product and can not help!!!!!!????
this is 6 months old.
Message 4 of 4
Hi @jessicaellis89 and thanks for getting back.
It's odd you were told that. Where did you purchase the monitor?
Cheers
David
