Message 1 of 6
BT Extender
Hello.
My BT extender disc keeps turning off and I've changed where its plugged into and it keeps doing it. Do you have a solution
5 REPLIES 5
Message 2 of 6
Re: BT Extender
Hi @JakeWhite815,
Welcome to the BT Community
Have you been able to try factory resetting the disc and repairing it to your hub to see if it stays on after that?
Alex
Message 3 of 6
Re: BT Extender
Hello.
Yes I have done this
Message 4 of 6
Re: BT Extender
OK, thanks @JakeWhite815
Please try re-connecting them following the steps on this Fix problems with Complete Wi-Fi help page.
Let us know how you get on please.
Chris
Message 5 of 6
Re: BT Extender
I have done all this and its just turning itself off and on
Message 6 of 6
Re: BT Extender
@JakeWhite815 It sounds like the Extender could be faulty if nothing has changed its behaviour, I would recommend getting in touch with our technical team for further assistance in getting it sorted for you.
Alex
