Message 1 of 4
BT Fault tracker down ? HTTP Error 502
Are elements of BT down ?
I can get to other websites and bits and pieces on MyBT - but they seem to have an issue with Fault tracker (for me anyway).
Anyone else getting this:
https://support.bt.com/track/fault/?view=faulttracker
This page isn’t working
www.bt.com is currently unable to handle this request.
HTTP ERROR 502
3 REPLIES 3
Message 2 of 4
Re: BT Fault tracker down ? HTTP Error 502
The link you posted works fine for me.
Try clearing your browser's history and cookies.
Message 3 of 4
I'd not thought of that. Thank you ! It worked - I did incognito mode.
I guess a BT site trick.
Much appreciated.
Message 4 of 4
Ah - it worked for a bit - but then this page didnt work and errored again.
https://www.bt.com/help/home/faults/
Could be my end - I guess !
I will try again tomorrow
