Message 1 of 3
Toggling off from FTTP to FTTC on Hub 2
Hello, I am on FTTC not FTTP.I have a new hub 2. I've been unable to toggle off the FTTP in the router settings.After clicking on SAVE a popup asks me to connect the internet cable to grey port (which I already did when I setup the new router)and click on OK which isn't showing on screen.
My question is this....  Since everything is working ok regardless of me changing the router setting from FTTP to FTTC can I just leave that as it is or is it important to change it?
2 REPLIES 2
Message 2 of 3
Re: Toggling off from FTTP to FTTC on Hub 2
you can just leave it.  if SH2 still 'thinks' port 4 is WAN then you can't use for ethernet like 1-3
Message 3 of 3
Thanx imjolly.If it's not important I'll leave it then
