Message 1 of 3
BT Hub 5 problem
I am unable to access my Hub5 at 191.168.1.254, I get page not found. I run troubleshooter and it tells me ' your computer appears to be configured correctly but 191.168.1.254 is not responding', then 'contact your internet provider'. The router is working fine and I've been able to access my hub previously so suggests a settings problem. But which?
2 REPLIES 2
Message 2 of 3
Re: BT Hub 5 problem
@thecatcher
Its 192.168.1 254 not 191.168.1.254
Message 3 of 3
Note that the dot is missing between the 1 and 254 in Keith's reply. It should read 192.168.1.254
