Message 1 of 8
BT Humax DTR-T2100
I have the above box in my bedroom and, until recently, it has worked OK. (I have a Samsung TV.)
Now it starts up 'BT waking up, after a while it shows 'youview .....Please wait'
After quite a while, it switches the box off (shows red on box) and starts all over again with 'BT waking up', etc.
I contacted Humax and they suggested I go into maintenance mode and reset. Their illustrations did not apply to the T2100 so I don’t know how to do this.
They have now told me to contact BT
Does anyone have the correct instructions please?
7 REPLIES 7
Message 2 of 8
Re: BT Humax DTR-T2100
Message 3 of 8
Thank you but no, this isn’t what I need.
I need the instructions for the T2100 to find how to enter Maintenance Mode.
Message 4 of 8
Message 5 of 8
How about this then.
"To enter Maintenance Mode on a BT DTR-T2100 box, restart it using the power switch on the back, then immediately press and hold the down arrow button on top of the box for 5 seconds until the "Enter Maintenance Mode" prompt appears on your TV screen. Once prompted, press the Standby/Power button on the box to open the menu."
Message 6 of 8
A reset is always worth a try, but it sounds as though the hard drive is toast.
The 2100 is quite an age now and if you've had ten years out of a hard disk then you've done really well.
Message 7 of 8
Thanks. I’ll give that a try.
Message 8 of 8
The BT support page
https://www.bt.com/help/tv/fix-a-problem/tv-boxes/how-do-i-reset-my-bt-tv-box-
does contain the reset guidelines if you click on the  box image (Recordable TV Box is the DTRT2100).
