Message 1 of 3
BT Mini Hub Halo - Replacement Battery
Can anyone tell me the correct replacement battery to purchase for a BT Mini  Hub Halo?  There appears to be no info on this I can find anywhere.  If anyone has one could you pop the back off and report the model number of the replaceable lithium ion battery?  Cheers, Ripface
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: BT Mini Hub Halo - Replacement Battery
Alcatel TLi021F7
Message 3 of 3
Perfect, thanks!!
