Message 1 of 3
BT Smart Hub 3 hotspot
Does SH3 transmit public hotspot signal?
If it does, where in the Hub Manager does it show that it is Active and how do you Opt In/ Out?
2 REPLIES 2
Message 2 of 3
Re: BT Smart Hub 3 hotspot
@Dippu  Apparently so, and if you Google your very question, the answer is there assuming one believes everything AI pushes out.
Message 3 of 3
Hey there, @Dippu
If you log in to the browser version of My BT, then select 'Your Products', you should see an option towards the bottom for BT WiFi.
Once you select this, it will give you an option to opt-out of this service which will also disable your hub from transmitting the public EE WiFi hotspot.
You can opt back into this at any time though, and you would regain access the the hotspot network with this too.
Peter
