Message 1 of 4
BT TV PRO box setup
I am trying to set up my new BT TV PRO box.
It gets as far as preferred region but then stops.
What should I do?
3 REPLIES 3
Message 2 of 4
Re: BT TV PRO box setup
Hi @IanBryan, welcome to the forum and thanks for posting.
I'm sorry that the box set up isn't working a smoothly as it should. If you're still experiencing a problem getting set up please Reset The Pro Box and see if that helps resolve the issue.
Cheers
John
Message 3 of 4
No problem.
It was all a misunderstanding.
I failed to follow the instructions.
Sorry and thanks.
Ian
Message 4 of 4
Hi @IanBryan, as long as you're up and running that's the important thing.
Cheers
John
