Message 1 of 2
BT Whole Home WiFi disc stand came off
I've got the white Whole Home WiFi disc (not the new one, the one without the circle design), I got it used from eBay.
The owner mentioned they super glued the stand but it came off upon delivery.
I see that there's a hole for a screw? I've opened the cover and there's no screws inside, I noticed it's been opened before, I don't know if these things come with screws or the previous owner took it off for some reason.
The two plastic bits to the left and right of the screw hole has come off so they're no use anymore.
Does anyone know the specification of the screw? I think the diameter is 4mm and the depth of the hole is about 3-4mm? I'm not entirely sure, would be grateful if someone could let me know!
Tags (3)
1 REPLY 1
Message 2 of 2
Re: BT Whole Home WiFi disc stand came off
Can't help with the screw I'm afraid, but I would use an 2 part epoxy glue (like araldite) to glue the stand on.
I've never found superglues to work at holding anything much together - except my fingers!
