Just to confirm that I'm right in thinking that this diagram is showing the master bedroom disc (main) connecting to each disc directly rather than in a daisy chain configuration?
Thanks in advance.
Hi @octopuswolf8172, welcome to the forum, and thanks for posting. Daisy chain connection for WHW has been discussed before Here and you may find some helpful information on that thread. If not then you would be best to get in touch with the WHW product helpdesk and they'll be able to answer your query.
You can call them on 0808 100 6116 (Mon to Fri 9am to 5.30pm and Sat 9am to 2pm)
Or drop them and email: btconnectedhome@bt.com
Cheers
John
