Message 1 of 3
BT dosc
I have a black BT Wi-Fi extender disc,  can I connect my Fire TV directly to it using an Ethernet cable?
Apologies if this has already been asked.
2 REPLIES 2
Message 2 of 3
Re: BT dosc
Short answer Yes
As long as the extender is paired up correctly and has a good connection (blue light is best) then you can connect any device via the ethernet port in the back
Message 3 of 3
Re: BT dosc
Thank you
