Message 1 of 2
BT hub randomly reassigns DMZ
I have an internal firewall set up in the router as the DMZ.
Seemingly at random the hub switches the ip for the dmz to a different device. Today it was my phone.
Apart from the inconvenience and loss of service this causes this is a huge security hole.
To clarify, the devices have not changed IP only the dmz pointer.
1 REPLY 1
Message 2 of 2
Re: BT hub randomly reassigns DMZ
Is the IP address of the device you wish to be in the DMZ outside of the DHCP range of the hub and assigned as a static address on the device itself?  It shouldn't matter, but it might be worth making sure that it is.
