Message 1 of 3
Hybrid connect
Does the Ethernet cable need to be connected all the time to the hybrid connect box from main hub
2 REPLIES 2
Message 2 of 3
Re: Hybrid connect
No, only to set it up. Once set up, it connects via WiFi.
Message 3 of 3
Re: Hybrid connect
No - just long enough to set it up, and then you can switch to wifi.
Full instructions here: https://www.bt.com/help/bt-halo/getting-set-up/setting-up-hybrid-connect
