Message 1 of 3
Black Wifi Disc has acquired a poltergeist
Hello all
One of the Black BT Wifi Discs https://www.bt.com/broadband/complete-wifi , the one closest to me during the day seems to have acquired a poltergeist. It's happened before, but now is more evident.
There is significant clicking (which does happen during a re-boot) but in the morning, the Disc has twisted slightly to its side, the result of hardware movement inside the unit.
Anyone else?
2 REPLIES 2
Message 2 of 3
Re: Black Wifi Disc has acquired a poltergeist
There's no moving parts inside, or at least there shouldn't be! I suspect the distortion to be caused by heat. I'd stop using it and unplug it immediately. Contact BT for a replacement unit.
Cheers
Ted
Message 3 of 3
@supertedster
Thanks, good advice and will do.
