Message 1 of 17
Broadband ac adaptor
I have a BT Smart Hub Type A router and require a longer ac adaptor cable to reach the wall socket
is there one available?
I’ve  seen extension cables advertised but they seem primarily for extending CCTV leads and I wondered if they worked with a router or whether degradation anyway.
can anyone advise me please ?
16 REPLIES 16
Message 2 of 17
Re: Broadband ac adaptor
can you not just use a power extension like a trailing 2/4 way socket
Anonymous
Not applicable
Message 3 of 17
Doesn't matter what an extension is designated for, you just need to ensure that the DC jacks are the correct size. Both inner & outer barrel dimensions & ideally length too.
Message 4 of 17
Thank you, and having the extension won’t affect broadband performance ?
Anonymous
Not applicable
Message 5 of 17
Not unless it's faulty.
Message 6 of 17
Many thanks for your advice 👍
Message 7 of 17
Hi,
Thanks for your reply , I’m afraid I’m not sure what that means, is it possible to post a link which would show me what you describe please ?
Message 8 of 17
Perhaps you haven't noticed , but posts just appear in sequential order so unless you quote the post or use the @ function to tag somebody, we have no idea to who or what your question is intended for.
Message 9 of 17
something like this
Message 10 of 17
@liquorice sorry I guess you can tell I’m new to this forum !
