Message 11 of 17
Re: Broadband ac adaptor
Sorry I didn’t realise you were referring to a general extension lead. I only have a double socket and one is using an extension of that is solely for the CCTV leads
I didn’t want to plug another one into the other socket as it will look a bit messy.
I also I thought I’d read somewhere that I shouldn’t plug the broadband adaptor into an extension
Message 12 of 17
Many thanks for your reply
Message 13 of 17
There is no problem plugging the hub power lead/adapter into the electric power extension. It won't affect your connection
Tags (1)
Message 14 of 17
@Yardo1
To reply to a particular post by quoting it, select the individual post you wish to reply to, click on the Reply button, then click on the 3 dots to expand the toolbar and then click on the quote button.
Alternatively, if you type the @character a drop down list of the respondents to the thread are displayed and you can select the one you wish to tag.
Message 15 of 17
Cheers , really appreciate you taking to the time to reply
Message 16 of 17
@licquorice thanks for that , hopefully I’ve tagged you successfully this time 😂
Anonymous
Not applicable
Message 17 of 17
A quick look at an old Type A Smart Hub seems to suggest that the centre pin is 2.5mm, whereas CCTV is generally 2.1mm. So just Google "2.5x5.5mm DC extension cable" & you should find want you need.
