Message 1 of 5
Broadband install
  • Had Hub delivered engineer arrived this morning only to be told he couldn't connect my hub as i had no phone line. This was explained when i took broadband contract out and was informed it wouldn't be a problem.  Now stuck with a hub that is no good and been on phone to customer service most of the held in queue for an hour and half still didnt get through. Dont know what to do ?
4 REPLIES 4
Message 2 of 5
Re: Broadband install
You don't need a 'phone' line, however you do need a physical line to provide the broadband. The engineer should
 have  provided it. You need to speak to BT.
Message 3 of 5
Would be nice if they would answer the phone lol
Message 4 of 5
Engineers are not sent to connect routers to existing ‘lines’ , so presumably the engineer was there to provide a new line or to ‘fix’ a line that was thought to exist but was testing faulty , so it’s a little odd for the engineer just to say ‘no phone line’ and leave , the lack of service that should not have been a surprise to the engineer , that what they were there to provider , so there must be a problem , it’s totally different for a tech to say , ‘you have no line and I can’t provide one ‘ because of (insert reason here ) , so what else did the engineer say ?
Message 5 of 5
Quick update managed to get through to customer service they said engineer made report that requires open reach to carryout a survey and install a new line. Why he didn't  say that I don't no. But should be done in a week orr so. Thankyou for all comments
