Message 1 of 5
Bt 8610 trio phone
We have a BT 8610 trio phone with Call Guardian, on incoming calls all three handsets usually ring in sync, but suddenly they are ringing out of sync, ( about 2second delay between each one), and its quite a din. I'd like to know if there is a way of fixing this, and resyncing them, without a total reset.  Thankyou..
4 REPLIES 4
Message 2 of 5
Re: Bt 8610 trio phone
Hi @Chalkiechicken, welcome to the forum, and thanks for posting.
That is an unusual problem and it may require a reset to fix it. However, you should have a look at the 8610 Product Help Page and the email and phone contact details are listed. They are best placed to help you with this.
Cheers
John
Message 3 of 5
Thanks John, I'll check that.
Anonymous
Not applicable
Message 4 of 5
Have you recently moved the base station or added any new devices that may be interfering? If not & you haven't already, I'd try powering off the base & all handsets for a couple of minutes Then powering on the base & then the handsets.
Message 5 of 5
Hi, not moved anything, or added anything,the only change was that I disabled Call Guardian, temporarily, but I'll try powering down everything. Thanks for your info.
