Message 1 of 3
Bt Wholehome stuck on purple light
Model: Whole Home Wi-Fi
One of my Bt wholehome disks has been stuck on purple more than 3 years and called "arcadyan default" so I cannot reconnect it to the mesh because it has gone back to the manufacturers default.
Does anyone know the default passwords for the extender so i could try and connect it to my computer and fix it's firmware?
2 REPLIES 2
Message 2 of 3
Re: Bt Wholehome stuck on purple light
To be fair, that sounds like the firmware went bad.  I'd doubt that short of some electical rework, you'll not be able to salvage it!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Anonymous
Not applicable
Message 3 of 3
@lewrab1
My Whole Home WiFi disks have a label on the back, (on a card that can be removed), that has both the default WiFi and Admin passwords.
