Message 1 of 3
Copying contacts
I am currently upgrading from a BT8500 to BT3110.  Is there an easy way to copy contacts without re entering data manually? What if I put one new phone in old system and sync numbers , then put new updated phone in new system base and sync with the two other phones?  Anyone tried it? Will it do any damage if I try?  As I am old , not very techie but have lots of good ideas, simple answers please.   Thanks, Rob
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Copying contacts
Pretty sure there's no way to do it as the contacts are stored in the base station & with option to export.
You could try the Help Desk but I wouldn't be hopeful.
0800 145 6789
Message 3 of 3
Thanks,
 I was hoping they would be stored on the handset . As the old one is playing up, I will persevere today and put all numbers in by hand.
 Thanks again,
 Rob
