Message 1 of 2
DNS setting
Hi was wondering if it is possible to change the routers DNS setting to another DNS setting to get a better connection in terms of speeds and security etc.
My hub is called BT smart hub 2 if this matters at all.
Thank you
Tom 🙂
1 REPLY 1
Message 2 of 2
Re: DNS setting
You can't change DNS servers on any of the BT hubs. If you wish to use different DNS servers you will need to change them on your device rather than obtain them via DHCP from the hub.
