Message 1 of 8
BT Whole Home Wi-Fi Dual Band AC2533 discs
Hi Community,
I have a the triple pack BT Whole Home Wi-Fi Dual Band AC2533 extender disc set up at present.
If I want to add more discs, do they have to be the same model i.e. AC2533?
7 REPLIES 7
Message 2 of 8
Re: BT Whole Home Wi-Fi Dual Band AC2533 discs
Hi, @ehtiahmed thanks for posting, yes if you're adding more discs they need to be the same model as the different models are not compatible.
Neil
Message 3 of 8
Thanks for letting  me know Neil. I'm assuming this model is still available?
Message 4 of 8
No problem @ehtiahmed, yes they're available on the BT Shop.
Neil
Message 5 of 8
thanks.
one last qs pls. on sites other than BT these discs are listed as AC2600 is that correct.
the link you sent has the following info:
Product codes
Quicklinx: CDXHRR00
Mfr#: 088269
Message 6 of 8
Hi @ehtiahmed
AC2600 seems to be the technology, so it's really a case of whether it's compatible with AC2533.
I've tried to find the answer but I don't have a definite answer, best advice I can offer would be to give the product helpdesk a call on 0808 100 6116. Having tried calling them there now, I can advise they are open from 9am to 5.30pm Monday to Friday.
Might be worthwhile ensuring compatibility before making the purchase, hope this helps.
Cheers
Stuart
Message 7 of 8
Thank you Stuart!
I'll give them a call tomorrow.
Message 8 of 8
Hi Stuart
I wonder if you can shed some light on the following pls:
I have bought 2 additional discs to connect to the same network I am using the other 3 on. I have a Virgin Hub 5 router.
However the 2 new discs are not connecting. I have managed to sync them to the router using the Ethernet cable provided, each one separately, but the Error code: Setup-042 keeps coming up on the app.
I have even done a factory reset at the back of each disc as suggested in one of the posts on the forum.
Help!!!
please!!!!
