Message 1 of 5
Data on a digital voice phone and how to recycle
My husband has a bt digital voice cordless handset that has died and he wants to get rid of it, but we don't know whether there will be anything that's been stored on it that will need deleting first and, if so, how to do it. Also how is it best to get rid of it? Can it be returned to BT somehow or should it go to the electrical bin at local council recycle centre?
4 REPLIES 4
Message 2 of 5
Re: Data on a digital voice phone and how to recycle
If you are BT customers you can get a replacement for it I would imagine alternatively you could ask for a free returns bag to send back via the post office (keep proof of postage until BT acknowledge they have it back)
If you are not BT customers you can send it back to BT at your minimal expense to this address:
WEEE Take Back Scheme
BT Returns
BT DF
Darlington Road
Northallerton
DL6 7ZY
As for data on the phone it would only be call history and contacts but if the phone has had it then that's not an issue anyway.
Message 3 of 5
Contacts are not stored on the handset, they are stored on the hub.
Message 4 of 5
@ValE
Before you bin the phone have you tried replacing the rechargeable batteries as there are numerous posts where the problem was solved by new batteries. You could try just using ordinary batteries to see if that brings phone back to life as long as you don't put on chaeger
Message 5 of 5
BT do not list the Digital Phone as an item that will be charged for if not returned.
https://www.bt.com/help/tv/how-to-return-and-recycle-your-bt-broadband-hub-and-bt-tv-box-fo
They were initially given as a free item but that is no longer the case.
Just take it to your local recycle centre.
