Message 1 of 5
Equipment Return - what needs to go back?
Can someone tell me what needs to go back to escape the £50 charge.
I have received the bag (more like a sack) and label.
MyBT account online says - You need to return these items -SmartHub2 (with serial number specified).
My question is, just the SmartHub or everything that came originally, i.e.  power adaptor, RJ11line/lead that goes into router, ADSL splitter/filter, Ethernet cable etc?
Any advice appreciated, trying to avoid BT maximising their profits.
4 REPLIES 4
Message 2 of 5
Re: Equipment Return - what needs to go back?
Just the Smarthub2.
Message 3 of 5
I’m just about to return my SmartHub 2 and was wondering whether there is any personal info retained on the hub, and how to erase it if there is?
Message 4 of 5
you can press the reset button on back of hub and hold for 20/30 secs until hub lights flash and that will return hub to how you received it  remember to get receipt of posting
Message 5 of 5
I just pressed the "reset" to go back to the default settings.
As someone has mentioned, keep your receipt. I was getting worried, BT took 6 weeks to acknowledge return.
