Message 1 of 2
WiFi disc software version?
I'm running the smart hub 2 on firmware version  v0.44.00.04123-BT. My wifi discs are on firmware version 0.41.00.07063. is this the current firmware version for the WiFi discs, or should it match the hub firmware version?
1 REPLY 1
Message 2 of 2
Re: WiFi disc software version?
The actual firmware files for different devices are *usually* tailored to the device, so, commonly, the firmware versions of different devices will not be the same.  Depending on how the version number/name is generated, they may never be the same!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
