Message 11 of 20
Re: Firmware Update v41 causing gaming issues
Have you got any ideas on how to rectify or do I just need to complaining to BT?
Message 12 of 20
Keep complaining, even it doesn’t get fixed. They need to know there is an issue. The more people complain increases the chance they will actually investigate and do something. You have to ask to speak to managers as they seem to be able to be more helpful. Do let them just say there is nothing they can do.
Message 13 of 20
@Hazza2107
After a firmware update, its best to do a factory reset of the home hub, as the new firmware is likely to contain changes to the configuration file which do not match your current working file.
By doing a factory reset, the latest version of that configuration file is loaded, which would then match the version included in the firmware.
https://www.bt.com/help/broadband/how-do-i-reset-my-bt-hub-to-its-factory-settings
Message 14 of 20
Reset the router about 100 times. Also got sent a brand new one last week. Issue still there.
Message 15 of 20
Variable response times are nearly always caused by something affecting the local network, like video streaming services running at the same time, or using a wireless connection instead of a direct Ethernet connection to the home hub.
Netflix is the worst offender, as it uploads data as well as downloading it.
Cloud uploads will also upset things. Things like OneDrive, Google Drive, or BT Cloud.
You need exclusive access to your Internet connection if you want to avoid poor response times.
Message 16 of 20
When I received the new router I didn’t connect any devices apart from one to test the connection. The issue was still there. There was no streaming, gaming, uploads or downloads happening. This is not a local network issue.
Message 17 of 20
Issue is identical to many of us with engineers confirming lines are okay, equipment switched out multiple times ans 1 device via ethernet cable with the problem being noticed at the start of december.
Message 18 of 20
Latency to the BT servers in London show major jitter and inconsistent latency spikes. 20mins after every factory reset or restart of the hub the latency consistently rests higher from around 7-8ms to 11-12ms with latency spikes.
This occurs no matter if the IP changes or not
Message 19 of 20
Hi @Spammy2  are you still having the same issues?
I’ve tried just about everything and still got the same issue
Last option is getting a PPPoe router and modem.
Message 20 of 20
I've got the best connection speed I've ever had but that could just be the recent switch to DV.
