Message 11 of 13
Re: Hopefully silly security concern about Hub Manager UI
Yes. Greater security now and a bit more fiddly to get to the hub manager but I'm used to it now.
Message 12 of 13
@nat_trea With an IP address of 192.168.1.254 it can't possibly be anything outside of your LAN.
Message 13 of 13
Yes, Licquorice makes a good point.
Certain address ranges are “private” in-so-far as they are only valid inside a network.  They will not work out on the internet because routers will not pass them on to the internet.
Anything beginning with 192.168.x.x is one such range.
That is why you can call your router 192.168.1.254 and I can also call my router 192.168.1.254.  Even Licquorice can call his router 192.168.1.254.  The whole world, his brother and dog can call their router 192.168.1.254.  They don’t clash with anyone else because they can’t go out onto the internet and cause confusion.  They are only valid inside a network.
That means 192.168.1.254 has to be a device inside your network.  Which is why I said it doesn’t need HTTPS and an encrypted connection, and you can ignore the “risky” connection warning.  You are hardly going to hack yourself after all.
