Message 1 of 6
How do I get a free hub upgrade from BT home hub 4
Hi I’ve for a long time had a BT home hub 4. My connection keeps intermittently dropping out on this. Someone I know rang up BT and got sent a new hub.  Have tried doing  this and don’t get anywhere??  Essential I’ve something reliable as I work from home. My current package says fibre 2 which I changed to in October 2023 so on this package until 2024. Any help gratefully received. Thanks
5 REPLIES 5
Message 2 of 6
Re: How do I get a free hub upgrade from BT home hub 4
I would be extremely surprised if the problem is the hub and a new hub probably won't help.
Have you reported the fault?
Message 3 of 6
Yes fault report engineer came out nothing weong
Message 4 of 6
obviously not moved to digital voice when you moved to fibre 2 otherwise you would have received a SH2
when you say dropping connection are you using ethernet or wifi connection when this happens?  does the colour on the hub change when this happens?
Message 5 of 6
Hi. I don’t have digital voice or been offered it yet. I connect via WiFi. When the connection drops the hub light goes from blue to flashing orange then after a minute or so goes back to static blue
Message 6 of 6
You have an intermittent line fault which is difficult to locate. Unfortunately, you need a diligent Openreach engineer to locate it and they are as rare as hen's teeth.
