Message 1 of 5
How to get the BT Pro box?
Hi. I have been with BT for around 6 years now, I have had the same equipment the whole time. I have just moved house and renewed my deal. I don’t want wires all over the house. Do BT offer new equipment for existing customers? How do I go about getting new equipment please?
4 REPLIES 4
Message 2 of 5
Re: How to get the BT Pro box?
I probably shouldn't say this but are you absolutely sure your existing box is working correctly?
If not, and if you are in contract then BT will replace it 😉
Message 3 of 5
Yes if you're in contract with a faulty box a like for like replacement is given not an upgrade.......
OP, if you go online or call up they'll look at the options for you
Message 4 of 5
Thankyou! I have had a nightmare but they are sending me some mini sockets instead to work with the current box wirelessly 🙂
Message 5 of 5
Thankyou! I have had a nightmare but they are sending me some mini sockets instead to work with the current box wirelessly! Appreciate the help!
