Message 1 of 2
How to switch back to normal internet from hybrid connect?
I recently got the hybrid connect with 4g and I tested it by unplugging the cable from my router so it kicked in. When I re plugged it in it was still using the 4g hybrid connect mobile internet for quite a while until I just turned off the hybrid connect completely so it would go back to using wired internet. How can I switch back to normal internet without having to switch off the hybrid connect when the time does come that I need to use it and go back to faster cabled internet?
1 REPLY 1
Message 2 of 2
Re: How to switch back to normal internet from hybrid connect?
When you are getting a broadband signal it will automatically start to use the Smarthub. This can take four or five minutes for the change back to the Smarthub to happen.
